Good afternoon.
Below are the description and possibilities.
You need to take it to someone who will do the proper diagnostics to determine the failure. Clearing the codes does nothing as the issue needs to be addressed.
It could be electrical or mechanical as the charts show.
P0734
Descriptor
Gear Ratio Error In 4Th
Probable Causes
Code Is Not Matching in Service Info File
Intermittent Gear Ratio Errors
Related Transmission DTCs Present
Transmission Mechanical Condition
Transmission Solenoid/Pressure Switch Assembly
Flow chart
Theory of Operation
The transmission control system uses three speed sensors, one to measure input rpm, one to measure Transfer Speed output rpm of the main transmission assembly, and a third to measure the final transmission output rpm. These inputs are essential for proper transmission operation. Therefore, the integrity of this data is verified through system checks. When in gear, if the gear ratio does not compare to a known gear ratio, the corresponding gear ratio error trouble code is set. The transmission will go into Limp-in mode after four gear ratio error events occur in a given driving cycle.
- When Monitored:
The Transmission gear ratio is monitored continuously while the transmission is in gear.
- Set Condition:
If the ratio of the Input RPM to the Output RPM does not match the current gear ratio when compared to the known gear ratio.
Always perform the 62TE Pre-Diagnostic Troubleshooting procedure before proceeding.See: Computers and Control Systems > Initial Inspection and Diagnostic Overview > Pre-Diagnostic Troubleshooting Procedure
1. CHECK IF RELATED TRANSMISSION DTCS ARE PRESENT
1. With the scan tool, read Transmission DTCs.
2. If any of these DTCs are present, perform their respective tests first.
Are there any Loss of Prime, Line Pressure Sensor and/or Speed Sensor DTCs present?
Yes
- Refer to appropriate diagnostic procedure in the Transmission category. If any of these DTCs are present, they will cause a gear ratio error. Perform the test for Loss of Prime first if it is present.
- Perform 62TE TRANSMISSION VERIFICATION TEST See: A L L Diagnostic Trouble Codes ( DTC ) > Verification Tests > 62TE Transmission Verification Test
No
- Go To 2
2. CHECK IF THE DTC IS CURRENT
1. With the scan tool, record the DTC Event Data, clear the DTC and road test the vehicle.
2. Try to duplicate the conditions in which the DTC originally set using the DTC EVENT DATA recorded.
Did the DTC P0734 reset?
Yes
- Repair internal Transmission as necessary. Check all of the components related to the UD, OD, DC and LC clutches. Inspect the Oil Pump and repair or replace as necessary. Refer to the Service Information for the proper repair procedures.
No
- Go To 3
3. CHECK FOR INTERMITTENT OPERATION
1. The conditions to set this DTC are not current at this time.
2. Check the gearshift linkage adjustment.
3. Gear ratio DTC's can be set by problems in the Input and Output Speed Sensor circuits. If the vehicle passes the Clutch Test and still sets a Gear Ratio DTC, check the Speed Sensors for proper operation.
4. Remove the Starter Relay.
CAUTION: Removal of the Starter Relay will prevent the vehicle from being started in gear.
WARNING: The Starter Relay must be removed. Failure to do so can result in possible serious or fatal injury.
5. Check the wiring and connectors for the Speed Sensors for a good connection, then perform a wiggle test using the Transmission Simulator, Miller tool #8333A and the Electronic Transmission Adapter kit.
6. This DTC can also be set under extreme temperature conditions, this is usually caused by an internal problem. Verify if the problem is only experienced under extreme hot or cold conditions.
7. With the scan tool, check the EATX DTC EVENT DATA to help identify the conditions in which the DTC was set.
8. Check for Service Information Tune-ups or Service Bulletins for any possible causes that may apply.
Were there any problems found?
Yes
- Repair as necessary.
No
- Test Complete.
792
P0792
Descriptor
Compounder Speed Ratio Error
Probable Causes
flow chart
P0792-COMPOUNDER SPEED RATIO ERROR
Theory of Operation
- When Monitored:
The transmission gear ratio is monitored continuously while the transmission is in gear.
- Set Condition:
If there is an excessive change in the Output RPM in any gear.
1. DETERMINING IF RELATED TRANSMISSION DTCS ARE PRESENT
Yes
No
- Go To 2
2. CHECK TO SEE IF P0792 IS CURRENT
Did the DTC P0792 reset?
Yes
- Repair internal Transmission as necessary. Check all of the components related to the DC and LC clutches. Inspect the Oil Pump and repair or replace as necessary. Refer to the Service Information for the proper repair procedures.
No
- Go To 3
3. Gear ratio DTCs can be set by problems in the Input and Output Speed Sensor circuits. If the vehicle passes the Clutch Test and still sets Gear Ratio DTC, check the Speed Sensors for proper operation.
6. This DTC can also be set under extreme temperature conditions. This is usually caused by an internal problem. Verify if the problem is only experienced under extreme hot or cold conditions.
7. With the scan tool, check the DTC EVENT DATA to help identify the conditions in which the DTC was set.
Yes
No
- Test Complete.
Jul 31, 2018 at 4:01 PM
