Transmission clunking causing transmission to lock into third gear, also check engine light on with code P0700
2008 KIA SPECTRA
155,400 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
GEEKOMETER96
  • 4 POSTS
Hello! I have the vehicle listed above Spectra5 that is having a strange transmission issue. While driving the vehicle, the engine will randomly clunk and the vehicle will stick itself in third or fourth gear. I am not 100%, but it could possibly be putting itself in limp mode. When the clunking happens, along with the transmission locking, a check engine light comes on with the code P0700.
I have replaced the motor mounts, noticing the amount of play the engine would have if running on a jack stand. That seemed to help for a small bit of time, but since has had random thunking attacks.
Any chance anyone has an idea on what might be going on with the transmission to be causing these issues? The car runs really fine for awhile, and then next thing you know it acts up again.
Sep 4, 2020 at 5:31 PM
The code you have is related to the transmission, so I suspect that is where you are hearing the noise. Here is the issue. The P0700 is more or less a generic code that sets simply to indicate there is an issue but further diagnostics are needed. A scan tool that can read all codes should be used in this situation because I feel the problem/code will be stored in the transmission control module and most basic scan tools can't read those codes. Actually, a scan of the entire can bus system should be completed. Here is a video that shows it being done:
https://youtu.be/InIlnsjOVFA
In this case, what is called "freeze frame" data should be reviewed before the code is cleared. Freeze frame data is just what it sound like. It is a snapshot of how several different sensors reacted when the fault was set. By reviewing that, it should help point us in the right direction.
Let me know if this helps or if you have questions. The vehicle should be further diagnosed before anything is repaired or replaced simply because we don't know yet what part of the transmission or transmission control module is causing the problem.
Sep 4, 2020 at 8:19 PM
GEEKOMETER96
  • 4 POSTS
Hello Joe,
I went ahead and got the freeze frame data from a Creader 4001 OBDII. I will go ahead and write out the information for you, because nothing I see on the freeze frame seems to have any noticeable value to me.
DTC that caused required freeze frame data storage - P0700
Fuel System 1 Status - OL-DRIVE
Fuel System 2 Status - ---
Calculated LOAD Value - 14.1%
Engine Coolant Temperature - 199F
Short Term Fuel Trim Bank 1 - 0.0%
Long Term Fuel Trim Bank 1 - -6.3%
Engine RPM - 1246/RPM
Vehicle Speed - 45MPH
Ignition Timing Advance for #1 Cylinder - 32.0 Degrees
Intake Air Temperature - 118F
Air Flow Rate From Mass Air Flow Sensor - 0.5lb/min
Absolute Throttle Position - 6.7%
Time Since Engine Start - 48SEC
Command Evaporative Purge - 0.0%
Fuel Level Input - 93.7%
Barometric Pressure - 32.1inHg
Control Module Voltage - 13.97V
Absolute Load Value - 25.1%
Fuel/Air Command Equivalence Ratio - 1.030
Relative Throttle Position - 0.8%
Ambient Air Temperature - 87F
Is anything here helpful enough for diagnosing what may have triggered the engine fault or the P0700 error?
Sep 5, 2020 at 6:37 AM
GEEKOMETER96
  • 4 POSTS
I went ahead and had a reputable transmission shop diagnose the issues.
The reported issues were bad solenoids, and a bad TCM. How much would I expect this repair to set me back if done from the Kia dealership it was originally bought from 12 years ago?
Sep 5, 2020 at 12:13 PM
To be honest, it would be odd for both a solenoid and TCM to go bad at the same time. Did they tell you what solenoid or solenoids?
As far as price, because of the model year, I don't have part information. However, I can't imagine it taking more than an hour to replace and program. As far as the solenoids, can you let me know which ones they told you need replaced?
Sep 5, 2020 at 6:35 PM
GEEKOMETER96
  • 4 POSTS
He did not tell me which solenoid(s).
He left me a sheet that just says:
P0743 Torque Converter Clutch Circuit Electrical
and
P0700 TCM Malfunction
Would it be worth it to just have him install new solenoids and a new wiring harness (I have heard there has been an issues with Kia Spectra's and wiring harnesses)?
To have the Kia dealership look at the car, they want $130.00 to have their mechanics analyze it themselves, which I just had done from another dealer.
Sep 6, 2020 at 8:35 AM
STEVE W.
  • 15,113 POSTS
P0700 is a generic -I have a problem in my transmission- code. It pops up only to tell a shop to scan the transmission control system for the real code.
P0743 is the actual problem code and it is a circuit code, which means the TCM sees there is a problem with the converter clutch solenoid or it's control wiring. Either shorted, open or it's getting the wrong feedback from the solenoid. It is very likely the wiring or connector for the clutch solenoid. Testing if it is the solenoid is easy and requires a simple volt ohm meter. You start by unplugging the transmission connector and measuring the resistance between the two indicated pins in the connector on the transmission. You should see 3.5 ± 0.2 ohms between those pins if the solenoid is good. If it tests bad then replace the solenoid pack, if it tests good, then inspect the wiring harness connectors and the harness back to the TCM. It doesn't take much to cause an issue.
Sep 6, 2020 at 1:50 PM
