(This only happens when i turn)
Rather I am at a complete stop and turn or slowing going around a turn. When I go to push the fuel pedal the transmission stalls in neutral then slams into gear hard. I plugged a scanner in and the only codes it brings up is p0442. Which is says small leak in the EVAP. Cannot find the leak. Would a small leak in the EVAP system cause my transmission to do that?
May 5, 2018 at 5:25 AM
