Transmission not shifting in from first gear?
2012 NISSAN MURANO
170,000 MILES • 4WD
not shifting in from first?
Mar 6, 2025 at 9:30 PM
This sounds like the input shaft speed sensor is not working, can I ask if you have check engine light on? If so, let's run the codes to help confirm the sensor failure.
Here is the sensor location in case a code comes up for it. Also, I would check the fluid condition to make sure it is not burnt. Check out the images (below). Please let us know what happens.
Mar 7, 2025 at 10:56 AM
