Transmission
2001 FORD F-150
155,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
JNUTT SR
Transmission will shift, but when given gas has no power. Installed a new shift solenoid , but no different. It also will not go into the designated position on the column. Like P R N D , the needle is off a bit. Also the overdrive light is flashing off and will not turn off or on.
Aug 2, 2016 at 8:55 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it.
Aug 3, 2016 at 6:59 AM
