Transmission it will not engage in four-wheel drive, where is the Bleeder Valve located?
1998 HONDA PASSPORT
143,000 MILES • 6 CYL • 4WD • AUTOMATIC
I changed the filter and fluid I put in as much as I took out but now it won’t engage in 4 wheel drive and the check transmission light is blinking on the dash. I was told that I need to bleed the air out of the transmission but cannot get an answer to where the Bleeder Valve is located on the transmission.
Dec 1, 2024 at 1:24 PM
You don't need to bleed the transmission, it sounds like you have added the wrong transmission fluid, can you confirm that you added.
Dexron-II Automatic Transmission Fluid
Also, do you have any warning lights on? If so, let's run the codes to see which ones are stored. This guide can help:
Dec 2, 2024 at 10:19 AM
