transmission
2001 SUZUKI JIMNY
890,000 MILES • 1.3L • 4 CYL • 4WD • AUTOMATIC
TRAMDATT16
My vehicle is not shift out of second no matter what I do. it is causing the engine to over rev and the auto shop computer is not picking any errors. what do i do ?
Jul 24, 2017 at 1:42 PM
This still could be a shift solenoid even though there is no codes for it. Drop the pan and remove it and check it. If it seems okay then you might have a servo seal that is out. There is a cover on the side with four bolts, check the o-ring.
Jul 25, 2017 at 1:45 PM
