For a couple days, my transmission was not shifting well from 1st to 2nd and 2nd to third. RPMs would jump 700 and then it would shift. At higher speeds it shifted smoothly. Then the check engine light went on and the opposite immediately happened. Smooth shifting at lower speeds but won’t shift into 5th gear at all. At 45 mph the RPMs were over 3,000. The mechanic said I needed a new transmission so I had him put one in, but the car still has the exact same problem. This is confusing to me and I’m not sure the mechanic knows what he’s doing. Can you please help?
Apr 11, 2023 at 12:18 PM
