transmission
2002 AUDI A4
140,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
PORSCHEGFT3
transmission lights flashing on dashboard, and when selecting gears, takes time to engage.
Oct 29, 2017 at 6:34 PM
MHPAUTOS
  • 31,937 POSTS
This flashing is a fault warning, you need to get the codes read and if you need further assistance post the codes here.
Oct 31, 2017 at 7:47 PM
PORSCHEGFT3
thanks for your response !! would it be a good idea to change the TCU, instead of redoing all the codes ??
thanks
Oct 31, 2017 at 9:09 PM
MHPAUTOS
  • 31,937 POSTS
no, because the transmission faults are generated by the transmission in 95% of the cases, check the codes first to see what they refer too first
Oct 31, 2017 at 11:23 PM
PORSCHEGFT3
thanks for your response !! so that means i have to get a OBD device to check the codes, or can i access them another way ???
thanks
george
Nov 1, 2017 at 1:41 AM
MHPAUTOS
  • 31,937 POSTS
you will require an OBD reader, some spare parts outlets will do a scan for free, but you can purchase a generic scanner fairly cheap, cheap scanners will only give codes with no definitions.
Nov 1, 2017 at 1:49 AM
