Hey BIGCOUNTRY6988,
If you get someone to put the vehicle in gear and watch the rear drive shaft do you see movement when the clutch is released?
No movement at the rear driveshaft and difficulty to engage gears would point to a clutch issue.
More than likely when it failed in 5th gear it would have over revved.
Are the gears easy to select?
Is there any noise when depressing the clutch?
Regards, Joe
Feb 17, 2020 at 7:39 AM
