Hard shift from park to reverse. Them want shit from first to any other gear. When it tries to shift stalls out.
Feb 29, 2016 at 7:16 AM
JOSHM009
MEMBER
It threw a 02 code changed 02 sensor. Now no code but still having the same problem. How do I get it to throw a code?
Feb 29, 2016 at 7:22 AM
HMAC300
CERTIFIED EXPERT
just have a trans guy scan for codes it may not be an engine / trans code but causing problem check all fuses under hood as well
Feb 29, 2016 at 7:23 AM
JOSHM009
MEMBER
Can you scan a transmission with a regular scan tool u buy from auto parts store?
Feb 29, 2016 at 7:25 AM
HMAC300
CERTIFIED EXPERT
yes but it may be fused or there iwiring issue and the connector isn't getting power so it can be read, besides if it's an internal problem maybe it can be fixed
