Transmission will not select gears automatically?
2007 HOLDEN ASTRA
19,688 MILES • 0.8L • 4 CYL • 2WD
LLAB1957
Removed the head and replaced valves and resembled. Car runs fine transmission has fluid but will not select gears automatically but will select manually. Transmission was working before I removed the head. Fuses are good.
Oct 18, 2024 at 9:32 PM
LLAB1957
Fuses are good.
Oct 18, 2024 at 9:34 PM
I would make sure all the of systems ground are connected, they can be left off while doing a big job like a cylinder head removal. If the grounds are all good let's run the codes to see which ones are stored, this guide can help:
Please go over this guide and get back to us. Can I ask if this car has a cable running to the throttle body?
Oct 19, 2024 at 9:43 AM
