Transmission not shifting properly
2003 CHEVROLET TRAILBLAZER
233,000 MILES • V6 • 4WD • AUTOMATIC
MEGB2089
When I go from 2nd into 3rd gear my RPMs rev really high and the truck does not shift into gear. I have to let off the gas and wait for it to fall back before I can press on the gas and it go into gear. This is the only gear it does it to.
Mar 31, 2021 at 7:01 AM
Good morning,
This could be the 2-3 shift solenoid not working correctly. You will need to drop the pan and filter to access the solenoid.
https://www.2carpros.com/articles/automatic-transmission-problems
I attached the procedure and pictures for you below. When one of these solenoids fails, they usually set a code with a check engine light.
Mar 31, 2021 at 8:07 AM
MEGB2089
I forgot to mention it is throwing 2 codes. One is p0171 and p0442.
Mar 31, 2021 at 8:31 AM
Neither one of those is connected to the transmission.
We will deal with them on another question. We can only deal with one issue at a time per question. You can start a new question with those codes and I will be happy to help
Mar 31, 2021 at 8:36 AM
MEGB2089
Okay, I won't worry about those codes for now. Thank you.
Mar 31, 2021 at 11:54 AM
You are welcome.
Always glad to help.
Mar 31, 2021 at 12:09 PM
MICHAEL POWELL
  • 20 POSTS
Was the solenoid the problem? And if you replaced it, did it work?
Thanks
May 9, 2023 at 11:14 AM
The person never provided a fix for the issue. Sorry about that. I believe I am working with you on a different post. If that is correct, I'll see you on that thread.
May 9, 2023 at 7:53 PM
