Transmission?
1999 LAND ROVER DISCOVERY 2
256,700 MILES • 2.4L • V8 • TURBO • 4WD • MANUAL
LEBZA12
Goes into gear but doesn't move.
Nov 23, 2022 at 8:58 PM
When in gear and you press the throttle, is the engine loaded, or does it rev as if it's in neutral? Also, have you checked the gear selector mechanism to make sure it is actually moving to shift the transmission?
Let me know. If the engine is just revving, there may be an issue with the clutch or drive component. If there is a load placed on the engine and it doesn't move, we need to determine what is stopping the transmission to turn. It could be a number of things.
Nov 24, 2022 at 9:21 PM
