TRANSMISSION
1997 DODGE RAM
186,000 MILES • 5.2L • V8 • 4WD • AUTOMATIC
JEFFREYJAMES
  • 5 POSTS
REPLACED CLUTCHES AND BANDS PUT BACK IN NO THROTTLE RESPONSE TO TRANSMISSION FEEL REVERSE GO IN BUT NO THROTTLE RESPONSE SAME WITH DRIVE REPLACED THE SPEED SENSOR THINKING THIS MIGHT BE EITHER GOVERNOR, TCC OR VALVE BODY ISSUE ;ALSO TRIED PULLING 8 PIN OFF AND SHIFTING EACH GEAR NO DIFFERENCE NO CODES, THROTTLE CABLE IS ALSO ADJUSTED PROPERLY WITH LESS THAN AN 1/8TH OF PLAY
May 13, 2024 at 10:07 AM
