The first thing to do will be to check the transmission fluid level. With the engine off there should be fluid on the dipstick. Next start the engine and check the fluid level again. It should be on or near the full cold marks. You say it is not moving, do you mean you have no vehicle motion regardless of what gear you select or if you rev the engine in gear or do you mean you can put it in drive or reverse but it will not shift but it does move in those gears?
Jan 27, 2020 at 5:01 AM
