Transmission
2003 HONDA PILOT
150,000 MILES
DANCINJUL
  • 4 POSTS
I am original owner of a 2003 honda pilot with 150k miles. When cornering or slowing down (not having come to a full stop), vehicle just shifts out of drive at around 1000-1100 rpm's. This happens only when rpm's are being reduced. When given gas to accelerate, engine just revs. When engine settles down to about 800 rpm's, I can resume acceleration, which is smooth through all the gears. No 'check engine' light comes on and therefore no codes. Tranny fluid is clean and red. I would like to have an idea of the problem before I take it for service. Thanks.
May 22, 2013 at 3:11 PM
KHLOW2008
  • 41,814 POSTS
Symptom indicates possible fault with transmission valve body. Transmission codes usually do not trigger the Check Engine Light, unless it goes into limp mode.
May 23, 2013 at 12:46 PM
DANCINJUL
  • 4 POSTS
Thanks. Do you have a ballpark estimate for repair cost?
May 23, 2013 at 5:54 PM
KHLOW2008
  • 41,814 POSTS
Repair varies according to location so you should check locally and it is best to have a transmission specialist look at it before committing.
May 24, 2013 at 7:49 AM
