transmission
1997 LEXUS ES 300
230,000 MILES • 6 CYL • FWD • AUTOMATIC
JOHN THOMPSON2
Transmission started slipping badly in all gears. I was able to get it home by pressing the interlock button. Flushed transmission fluid and it worked great for a few weeks then started slipping again. Replaced the filter and fluid (not a total flush)and it worked for a couple of days and then same thing. So another filter and some new fluid. Now I am slipping in forward gears until gear engages at high rpm. But now no overdrive and reverse is now working fine.
Jul 12, 2017 at 4:34 PM
STEVE W.
  • 15,113 POSTS
That description sounds like you have some crud from worn parts floating around inside blocking items in the valve body from operating. But with the slipping I would have the transmission pressure tested while on the rack. It is possible that there is hidden damage from debris or failed components from the earlier problems. A good transmission shop can test it and give you options much better than trying to test it yourself.
Jul 12, 2017 at 9:46 PM
