transmission
2000 CHRYSLER SEBRING
62,000 MILES • 2.5L • 6 CYL • FWD • AUTOMATIC
CHANRAHAN
  • 5 POSTS
I recently had the transmission flushed and it was replaced with a universal synthetic transmission fluid. *I've had the car a week.Anyway after coming to an abrupt stop from 40. The engine cut out after a hard down shift to first. Could it be the torque converter? The shop said give the atf 250 miles to work it in.
Apr 19, 2016 at 8:23 AM
HMAC300
  • 48,601 POSTS
normally the converter clutch has been released by that time. butif they stick they can do that. Most trans shops do not flush fluids they change it. give it time and see if anything else goes wrong with it.....it may disappear
Apr 19, 2016 at 9:28 AM
CHANRAHAN
  • 5 POSTS
Thank you. The normal fluid was changed out andreplaced with synthetic. My brother and I watched the process with the machine. I will give it some more time and see what happens
Apr 19, 2016 at 3:31 PM
