Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
F-350
Drivetrain
Transmission
Symptoms
Disengage
Transmission intermittently disengages
1996 FORD F-350
100,000 MILES • 7.5L • V8 • 4WD • AUTOMATIC
DBAIER
MEMBER
1 POST
FOLLOW
Transmission intermittently disengages at highway speed then drops back in with a bang. Speedometer also jumps over 40 mph. Related?
Feb 7, 2020 at 2:33 AM
CERTIFIED EXPERT
Good morning,
Did you check the fluid? A low fluid level or a clogged filter would cause this issue. I would start by changing the fluid and the filter.
Are there any codes set?
Hopefully changing the fluid and filter will resolve the issue. This transmission did not have a good reputation. It had a high failure rate.
Feb 7, 2020 at 5:34 AM
