Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Toyota
Tercel
Drivetrain
Differential
Gear Oil
Service
When changing different which fluid do I use
1997 TOYOTA TERCEL
200,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
KEVNLKING
MEMBER
FOLLOW
I have a three speed automatic transmission. When changing the differential fluid do I use gear oil or do I use transmission fluid?
Aug 20, 2018 at 1:21 AM
CERTIFIED EXPERT
Good morning.
It takes ATF.
Recommended ATF is Dexron II or Dexron III.
Aug 20, 2018 at 3:46 AM
KEVNLKING
MEMBER
Do I use gear oil or transmission fluid for the transmission gearbox on the rear of the transmission?
Aug 20, 2018 at 1:20 PM
CERTIFIED EXPERT
As listed above, it takes the same fluid.
Use Dexron 2 or 3.
Aug 20, 2018 at 1:23 PM
