Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Hyundai
Elantra
Drivetrain
Transmission
Symptoms
Not Shifting
Transmission not shifting into gear
2002 HYUNDAI ELANTRA
236,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
JACKSONBROWN
MEMBER
1 POST
FOLLOW
Will not shift into gear.
Jan 1, 2019 at 4:50 PM
CERTIFIED EXPERT
Good morning,
Did you check the fluid feel?
https://www.2carpros.com/articles/automatic-transmission-problems
Does the shifter feel the same as it always has? if there is an issue with the cable, it would seem loose or not normal.
How long since the fluid and filter was changed?
Jan 2, 2019 at 4:24 AM
