Transmission not shifting into gear
2002 HYUNDAI ELANTRA
236,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
JACKSONBROWN
Will not shift into gear.
Jan 1, 2019 at 4:50 PM
Good morning,
Did you check the fluid feel?
https://www.2carpros.com/articles/automatic-transmission-problems
Does the shifter feel the same as it always has? if there is an issue with the cable, it would seem loose or not normal.
How long since the fluid and filter was changed?
Jan 2, 2019 at 4:24 AM
