transmission
1983 DODGE RAMCHARGER
150,000 MILES
KERGAN
  • 4 POSTS
The 4 speed manusl transmission just fell apart on my 1983 dodge ramcharger. I would like to put a 5 speed in it but they didn't have 1 in the 80's. I know that they started to put them in the Ram in 1994. I think I can get ahold of one of these. Will the 1994 5 speed transmission mate up with a 1983 318 engine?
May 29, 2013 at 4:03 PM
CARADIODOC
  • 34,306 POSTS
I have the four-speed in my '80 Volare. It is a really tough transmission and was used all the way up to a two-ton dump truck. It is a lot tougher and heavier than the five-speed.
You'll find the splines on the input shaft are different so it won't fit the clutch disc. If both discs are the same diameter you might get the newer one in but if the thickness is different you'll need the newer pressure plate which likely will not bolt to the flywheel.
Next is the matter of the shifter and linkage. You'll have to look at how each shifter is mounted to figure out if the new one will hit the dash and come through the floor in the right spot. The linkages may hit the existing body or cross members.
I think you'd be better off finding the right replacement. The four-speed used in my Volare had an overdrive gear installed to replace the third gear set, then the shift lever was flipped over to switch third and fourth gears. That means shifting to third gear puts the transmission in fourth and a one-to-one ratio, and shifting to fourth puts the transmission into third gear which is an overdrive ratio now. You can identify that by looking at the two shift levers on the transmission. One will be going up and one will be down. The five-speed will give you the same thing, just with one extra gear to shift through to get there.
May 30, 2013 at 9:46 AM
