Transmission
1985 NISSAN 300ZX
150,000 MILES
NEZYWICK
So while driving the 300 ZX when pressing in the clutch there is a grinding noise, pulled apart the transmission and took out throw out bearing, it spins just as easily as the new one I bought. Doesn't seize at all, just wondering what else it could be, or if it is the throw out bearing. just don't want to put it back together and then have to take back apart
May 9, 2013 at 7:56 PM
HMAC300
  • 48,601 POSTS
check the bearing in end of crank or bushing if there is one. then check input bearing on transmission.Also was trans full ? moverelease bearing slowly and see if youcan feel roughness if is replace it
May 10, 2013 at 6:08 AM
