When I slow down I feel a clunking noise and then it will not go back into fourth gear
2002 CHRYSLER CONCORDE
158,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
JESSE FRANK
  • 8 POSTS
Most of the codes are saying that there is low voltage. How do I know it's electric, and not the transmission? I changed the transmission fluid and filter and it still does it. How can I determine what the issue is?
Apr 10, 2020 at 5:35 AM
Good morning,
Can you list the codes for me so I can see where I can help narrow the area of failure?
https://www.2carpros.com/articles/automatic-transmission-problems
I need the codes to help you.
Apr 10, 2020 at 5:40 AM
JESSE FRANK
  • 8 POSTS
The codes that I have are, p0736. P0841,p2776,po481, po300. And po700. Thanks for the help.
Apr 10, 2020 at 4:49 PM
Okay, the 736 is the key. That is a ratio error which means it is slipping internally.
That will require removal of the transmission and either a rebuild or replacement
Apr 10, 2020 at 5:19 PM
JESSE FRANK
  • 8 POSTS
Is there any way around rebuilding the transmission? Do you think that there is a bad connection or a short in the wiring?
Apr 10, 2020 at 5:31 PM
No, not for the gear ratio code.. You can continue to drive it for now but it will get worse over time until you are restricted to one forward gear only.
Apr 10, 2020 at 5:35 PM
