Transmission is slipping out of gear
2005 CHEVROLET TRAILBLAZER
120,000 MILES • 4WD
EMILYAYERS
I was at a stop and went to turn onto a road (a little quickly cause there was traffic coming) and the car slowed and stopped going forward like it was in neutral. The gas gauge dropped immediately. I pulled off to a side street and turned it off. When I turned it back on it was fine. I checked the fluid and it is okay. Just fix the drive shaft, check engine light (x3), fuel pump and brakes on the car three months ago.
May 2, 2019 at 2:03 PM
Thanks for the details on this question. it sounds like the PCM is going out, but we should run the codes again to see what comes up. here is a guide to help us fix the problem:
Please run down this guide and report back. Here is the PCM location I would check the connectors and see if there is any water damage. Check out the diagrams (below). Please let us know what you find.
May 4, 2019 at 10:55 AM
