the box truck runs fine but the transmission will not auto shift on it own; once I stop I must manually place auto lever in lowest gear then manually shift it up to next higher gear to make transmission achieve higher gears.
is there a module of some type that's gone bad or is transmission on its way out?
thanks
thanks
Mar 13, 2021 at 11:01 AM
