When I put it in drive it will go but it will not shift out of first. Now sometimes it will shift but when it does the mileage goes blank (----------) and the overdrive light starts flashing. It will shift fine for a little bit, for instance lets say I get on the highway it will it will go for about a 1/4 mile and then it looses power. like the gears are not engaging. I took it O'Reilly's and got it scanned and says all four O2 sensors are bad, EGR valve and the speed sensor was bad, I replaced the speed sensor and I am still having the same problem. Now if I manually put the car first gear and shift to second it does fine, but I still need third and fourth.
Mar 9, 2017 at 8:08 AM
