Codes P0740, p0753, p0785, p1860?
2000 CHEVROLET TAHOE
180,000 MILES
EARL91
  • 89 POSTS
I have the vehicle listed above Z71 5.7L. codes P0740, p0753, p0785, p1860. It has a transmission in it that was refurbished 2 years ago. I installed a new create motor about a month ago. I check shift solenoid A and B. Both are working and receiving between 20 and 25 olm's about 21.7 to be exact. What are some things I can do to fix? Working on a budget.
Apr 25, 2023 at 4:31 PM
Here is information on the codes:
P0740: Torque Converter Clutch Circuit Malfunction.
P0753: Shift Solenoid A Electrical Malfunction.
P0785: Shift/Timing Solenoid Malfunction.
P1860: TCC PWM Solenoid Circuit Electrical Malfunction.
I would start by checking the electrical connector at the transmission. If that looks okay, I would install a rebuilt valve body. Check out the images (below). Please let us know what happens. Also, how is the fluid condition, is it burnt or low?
Apr 27, 2023 at 10:17 AM
EARL91
  • 89 POSTS
The fluid is good. I dropped the pain and checked the shift solenoids, and they were good. I cleaned everything while I was there. Changed the filter and put new fluid in. Do you think putting a new harness in would fix my problem? i have done a little research and it seems that that could possibly fix it.
Apr 28, 2023 at 6:30 AM
Yes, if the wiring is bad, it will cause this problem. Here is a guide to help you test the wiring with the transmission wiring diagrams below:
Apr 29, 2023 at 11:21 AM
EARL91
  • 89 POSTS
The valves in the valve body moved easily. So, I don't think it's that. That why I asked about harness. Thank you for the info. I will let you know how it goes.
Apr 30, 2023 at 7:49 AM
EARL91
  • 89 POSTS
The valves in the valve body moved easily. So I don't think it's that. That why I asked about harness. Thank you for the info. I will let you know how it goes
Please do, have a great day.
Apr 30, 2023 at 10:52 AM
EARL91
  • 89 POSTS
i replaced the harness in the transmission. the truck can move better. i don't have to almost floor it to move. but the codes are still there after clearing them with the scanner. also still can't feel or hear the truck shift. What would the next step be?
May 12, 2023 at 10:56 AM
I would install a rebuilt valve body, or you could have a bad PCM. How is the fluid condition?
This guide can help:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
May 13, 2023 at 10:05 AM
EARL91
  • 89 POSTS
Can a bad ignition switch cause these shifting problems? My tachometer and speedometer on my cluster stopped working. And then all these problems started.
May 18, 2023 at 5:36 AM
Yes, it could, here is how to change the switch out in the images below. Check out the images (below). Please let us know what happens.
May 18, 2023 at 12:25 PM
EARL91
  • 89 POSTS
Ignition switch did not .
May 28, 2023 at 8:57 AM
It seems like it is the valve body or the wiring, did all of these codes come in only after you changed the transmission out?
May 30, 2023 at 9:20 AM
EARL91
  • 89 POSTS
Okay. So, I bought this truck. The motor was locked up. It blew the cylinder walls out. So, I put a new motor in. The transmission was rebuilt about two years ago. It was all running good for about two weeks then all of the codes appeared. I have changed the internal harness. All new solenoids, new filter. And ignition switch. The only thing I haven't changed is the valve body and pump.
Jun 1, 2023 at 5:40 AM
EARL91
  • 89 POSTS
I'm also going to check my converter make sure it's not loose.
Jun 1, 2023 at 5:41 AM
EARL91
  • 89 POSTS
Any way you could send me all wiring diagrams for my transmission?
Jun 1, 2023 at 8:41 AM
They are in the post above, click to enlarge in the images.
Jun 2, 2023 at 8:19 AM
EARL91
  • 89 POSTS
could the gauge cluster not working cause my no shift issue?
Jul 13, 2023 at 1:41 PM
So, the speedometer is not working? If so, this can be the problem, I would swap out the VSS sensor. Check out the images (below). Please let us know how it goes.
Jul 14, 2023 at 8:57 AM
CHRIS MORGAN4
I know this is an old post but did you ever find a solution? I have a 02 Escalade with the exact symptoms.
Oct 15, 2024 at 7:37 PM
Good question, I just spoke with EARL91 so he should respond. I think the transmission needed to be rebuilt.
Oct 16, 2024 at 10:39 AM
EARL91
  • 89 POSTS
The gauge cluster being replaced did fix my issue.
Oct 25, 2024 at 4:50 PM
So the cluster caused those codes? Thanks for letting us know.
Oct 26, 2024 at 9:26 AM
