Good morning,
You will need to verify the input shaft is the same splines as your original transmission. If it is not, then you need to replace the clutch with the correct spline on the disc.
https://www.2carpros.com/articles/transmission-replacement-removal-manual
Make sure the linkage is the same if it has any. Most are just sticks through the floor.
I attached the procedure below for you to view.
Jan 4, 2022 at 4:19 AM
