I recently replaced the transmission with a Japanese used transmission. I'm not a mechanic.so we picked up the transmission they told me to switch the speed sensor from our old transmission. the installation went well. shift cable is okay, goes into park and all gears. the car starts off in fourth gear then after it's moving you can push down the throttle and it down shifts. if I manually pull linkage into first still takes off in fourth. I thought the plugs were straight forward. could I have mixed the plugs and get these results? the car is 2.3 liter, so sorry.
Apr 2, 2019 at 8:49 AM
