Transmission
1998 DODGE DAKOTA
200,000 MILES • V8 • 4WD • AUTOMATIC
TPAYTON9596
I have no park, reverse, no first or second gear. I can put it in drive and hit gas pedal and it will take off.
Dec 17, 2018 at 2:32 PM
Good evening,
If you have no movement, how does it take off? please explain?
https://www.2carpros.com/articles/automatic-transmission-problems
Dec 17, 2018 at 8:43 PM
TPAYTON9596
I start truck move shifter to reverse it won't move but sounds like and looks like it trying to move forward same for neutral. Then if I shift to drive and give it a lot of gas it will move forward. If I drop it to first or second gear it won't pull but you can tell it is trying to. Then I can move it back to neutral then give it gas and it will take off forward like its in drive. I put new fluid in changed filter, and put new shifter cable on. Some the vacuum lines are off but none go to transmission.
Dec 18, 2018 at 12:23 AM
Okay, thanks.
You have an internal failure in the transmission. it will have to be removed and inspected for the failure and most likely rebuilt.
Dec 18, 2018 at 2:27 AM
