not shifting I think it’s an electrical issue
1997 CHEVROLET 1500
167,000 MILES • 5.7L • V8 • TURBO • 4WD • AUTOMATIC
TEEGEE
I think it’s an electrical issue. Changed fluid and filter no metal debris. Any suggestions. The code transmission pressure low circuit c.
Dec 8, 2020 at 9:14 PM
Can you provide the actual code and we can get the detail. However, you are more then likely correct as those pressure codes are most likely electrical issues.
So let's scan the vehicle and get the actual code and we can go from there on what we need to do to figure out the actual issue.
Thanks
May 14, 2021 at 11:22 AM
