Transmission.
1995 LEXUS SC 300
140,000 MILES
AVAGD001
My transmission wont shift on the 4th gear.
It goes to 45 and wont shift no more.
The car runs beautiful except it wont shif the last gear and it just winding out at 45 miles per hour
The mechanic put a speed sensor on the car but that didnt work.
He says when you take the negative terminal off the car shifts all 4 times but only once makes no sense?
He is a mechanic from years back and he has had my car for over 1 month.
He says he doesnt have the proper computer to properly check it out.
As soon as you get up to 40 to 45 miles per hour when it should shift to the last gear it doesnt.
The mechanis seems to think it is not internal but something else but what?Someone said maybe it is a module if I speeled it correct?
May 25, 2013 at 2:24 PM
KHLOW2008
  • 41,814 POSTS
Since it is able to shift after resetting the control module, it means the computer has gone into limp mode when it detects a fault in the system.
You need to check for trouble codes and if the mechanic is not familiar with this system, it is time to get a new mechanic to check the problem.
May 25, 2013 at 9:53 PM
