Transmission, A/T FR/B Solenoid Valve Circuit Malfunction
2003 INFINITI G35
155,615 MILES • 6 CYL • AUTOMATIC
LA.VERO
  • 40 POSTS
Check light came on had code read and says A/T FR/B Solenoid Valve Circuit Malfunction.
If i'm stopped and drive the car wont go. i step on gas and is slowly driving takes awhile to kick in and drive or wont drive at all.
Does this sound right?
Sep 21, 2021 at 1:03 AM
Good morning,
I need the code number to help you. It should start with a P and then some numbers.
As far as the operation, I would start by changing the fluid and filter. If you have a clogged filter, it will act like this.
https://www.2carpros.com/articles/automatic-transmission-problems
Sep 21, 2021 at 4:32 AM
LA.VERO
  • 40 POSTS
P1757.
Sep 21, 2021 at 9:53 AM
Thank you.
The code is for the front brake solenoid circuit. This is located in the ABS module and has nothing to do with your issue.
Did you get the fluid changed yet to see if that is the issue?
Sep 21, 2021 at 10:46 AM
LA.VERO
  • 40 POSTS
No, i have not.
So the code has nothing to do with transmission?
Sep 22, 2021 at 10:41 AM
Correct. It is part or an indicator of an issue with the ABS.
Sep 22, 2021 at 11:01 AM
LA.VERO
  • 40 POSTS
Oh gosh.
When i put into Drive step on gas it would take a few seconds to kick into gear. Now it does not go at all. A few people. Told us it was transmission, so my son bought one over the weekend. I feel real stupid.
Sep 22, 2021 at 11:06 AM
Did you change the fluid? I would try that first before buying a transmission.
Sep 22, 2021 at 11:12 AM
LA.VERO
  • 40 POSTS
Have not done anything only the code reader 3 times. He already bought the transmission. We picked it up in Saturday from Sacramento.
Sep 22, 2021 at 11:14 AM
I would change the fluid first. It is about $89.00. A lot cheaper than replacing the transmission.
Sep 22, 2021 at 11:19 AM
