Good afternoon,
Does the gear shifter move to select all other gears?
Do you mean no matter where you place the selector it is always in reverse?
Did you check the shifter cable to be sure it is moving the manual valve on the transmission?
Can you give me as much information as possible?
https://www.2carpros.com/articles/automatic-transmission-problems
Nov 28, 2018 at 12:55 PM
