Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Hyundai
Veracruz
Warning Lights
Check Engine Light
Check engine light is on and transmission is stuck in third gear?
2007 HYUNDAI VERACRUZ
178,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
[email protected]
MEMBER
1 POST
FOLLOW
My transmission is stuck in 3rd gear my check engine light is on it says I need a mass air flow sensor. could that be the problem?
May 6, 2021 at 10:26 PM
CERTIFIED EXPERT
Good morning,
Codes do not tell you to replace anything. They tell you there is a failure in that system.
https://www.2carpros.com/articles/how-a-mass-air-flow-sensor-works-maf
Can you list the code number for me to see? Then I can check that code to see if there is a connection to the transmission issue.
https://www.2carpros.com/articles/automatic-transmission-problems
Have you changed the fluid in the transmission?
May 7, 2021 at 5:50 AM
