Car has sat for two to three years. Had no issues before it was parked and transmission. It was rebuilt couple years before that and worked fine. I want to start driving car again but it will not move in any gear. If you start engine, turn off, start again and do this a few times, it eventually will move in the gear you select, but if you stop, it will not move again. Transmission fluid level is normal and linkage is intact. Car sat outside all the time also. Located in Florida.
Sep 2, 2018 at 11:52 PM
