Transmission stopped shifting
2007 CHRYSLER TOWN AND COUNTRY
176,000 MILES • 3.8L
DUSTY MARIE
It still runs. grinds when you put it in park shut van off and you can push it in every gear. there wasn’t any transmission fluid coming out until I changed the transmission shift solenoid, now their fluid pouring out some where either from new part or transmission pan.
Dec 31, 2019 at 8:38 AM
TOUGHDIVER
  • 224 POSTS
If your vehicle is grinding when you stop and put it in park with the engine running, It sounds like you broke a half shaft/(axle) shaft, This should be preformed by a certified Service Mechanic (Note: Block the rear wheels) put the vehicle in neutral, jack up the front of your vehicle one side at a time. (Note: using the instructions in your owner's manual) and turn the drive wheels in an clockwise or counter clockwise rotation by hand while observing the axle and C/V joints for for Breakage and leaking grease out of the C/V boots at both inner and outer on both sides, You need to hold the axle and rotate the drive wheel to see if the axle is moving it should rotate with very little side to movement, If the axle stays stationary while turning the wheel there something wrong .I'm attaching a video on drive axle removal and replace drive below,The ATF leak might be related to the broken axle it may have damaged the axle seal, Or torque converter seal could leaking, Check the transmission pan gasket it could be leaking. I'm attaching a video on oil pan replacement. Please let us know if this information was helpful and what fixed the vehicle. If you need more help with this contact us right away.
https://youtu.be/0Y-0fIBcBBs
https://youtu.be/miNxBZIQRRM
Thank you
Joe Terwilliger
Jan 1, 2020 at 11:39 AM
DUSTY MARIE
Okay, so we replace the gasket an filter for transmission pan put seal on it also. Put a new transmission shift solenoid on and it’s still pouring out transmission fluid. I turn into a parking lot before all this and I was coming to a stop and that’s when it stopped shifting, but stayed running. we checked the shifts cable and it was still connected. once we put it park it sounded like metal being crunched together .
Jan 3, 2020 at 10:37 AM
TOUGHDIVER
  • 224 POSTS
It really sounds like you have an broken axle, It's possible the torque converter is faulty and blow the torque converter seal and that's why there is a massive transmission fluid leak
If you are having trouble pinpointing the leak add some transmission fluid dye, (You can get this at most any parts store), it will show you were the fluid is coming from, The dye will really show up with a ultraviolet light, but you can still see without one but not as bright,
The torque converter can make your vehicle not to engage into gear and grind while putting it into park.
A broken axle will make your vehicle not move when your in Drive and grind when putting it in park, It will also make a grinding noise when you put into park because when you stop the vehicle the will keep turning causing a grinding noise,
Imagine you are driving down the road and to put your vehicle in park,( It would make a noise right)?
I'm attaching a links and videos below on common oil leaks and what signs to look for,
Let us know if this information is helpful and if you need more help and we'll get it for you.
(Note: if you can send us a video of the noise and a couple of nice picture of the bottom of the transmission it would be a big help diagnosing the transmission noise and leaks).
https://www.2carpros.com/articles/engine-is-leaking-oil
https://youtu.be/XUwsMjLP7HU
https://youtu.be/XOTMDKyZmEs
Thank you
Joe T.
Jan 3, 2020 at 12:15 PM
