when I go over even small bumps it acts like it is going to shut down?
2006 CHRYSLER PT CRUISER
94,508 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
AMY MARIE
My car has been revving up when I turn it on for the last couple days and when I go over even small bumps it acts like it's going to shut down. It started bout 2 days ago on way back home from town my engine started revving really high between to the 6-7 range and wouldn't shift into gear at all I had to pull over about halfway home to manually shift it into first and that didn't help either. I live about 20 or so minutes from town and I barely made it back home before it started to stall out and shut off. when I turned car off it did smell like something was burning, but no smoke coming out of from hood was actually cold and smell only last couple minutes so I parked it overnight and then drove it bout 1/4 mile to work and back home it still revved up but not as bad. Then I drove it again today after putting Lucas stop slip in, it barely made to store which was about 10 or so minutes away from my house. It shifted a little bit but then started to stall and did the same on way back from store tried to stall again.
Sep 8, 2022 at 4:22 PM
So, does it seem like the transmission is slipping or not shifting? If the problem is not shifting, I would say the TIPM is going out which is common, but it is easy to replace because it self learns. To be sure you should do a CAN scan which is easy to do, you can get a CAN scanner (Controller Area Network) from Amazon for about $30.00.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is a scanner link:
https://amzn.to/3o41KcZ
Here is how you can change the TIPM out. Check out the images (below). Please let us know what happens.
Sep 9, 2022 at 12:24 PM
