Transmission went into reverse but now it will not go into gear or anything. It just stays in neutral and seems like it cannot locate the linkage.
May 6, 2018 at 5:10 PM
CERTIFIED EXPERT
Good morning.
Some checks:
1. Check fluid level.
2. make sure the linkage is working correctly.
3. I would start by dropping the pan and checking to see if the filter is blocked.
May 7, 2018 at 4:09 AM
RENEE L
CERTIFIED EXPERT
Hello GIZM2450,
Here is a link to an informative article from this site that shows you step by step what to check when your transmission will not go into gear.:
