transmission
1980 JEEP CJ5
125,000 MILES • 2.1L • 6 CYL • 4WD • MANUAL
JAGA5
i was driving around fine but, when i got home i only had second gear, neutral, and reverse. in neutral i also had reverse.
Oct 28, 2017 at 2:32 PM
CJ MEDEVAC
  • 11,004 POSTS
SR-4 or T-176? (4 speeds)
Is this Jeep stock?
Can you explain the situation a little better than in your initial question?
Do you drive like Grandma (like me) or are you really hard on your Jeep?
Run thru the gears sitting still (1, 2, 3, 4, R) Explain how they feel as you enter and exit each one. (or will it even go into positions?)
The Medic
Oct 30, 2017 at 3:01 PM
