When driving if I speed up or go under load the trans shifts and shudders for a couple seconds until I let off and give more throttle.I was told by a fourm it sounds like torque converter shudder The trans is an e40d will a shift improver kit and filter fluid change help or fix this. There is no slip and all gears work fine except the shudder at low rpms
Jan 23, 2016 at 5:40 PM
