Transmission shifting hard
1989 DODGE RAM
65,000 MILES • 5.2L • V8 • 2WD • AUTOMATIC
KASHAYA
  • 6 POSTS
i just had my transmission on my truck listed above 1500 rebuilt by a local shop. transmission still shifts hard in reverse and drive, shifts fine when driving on freeway. Transmission is A500.Took back to shop and they turned idle down which helped a little. The owner of shop told me that the hard shifting was normal for this year, by the way i just bought this pick up a couple months ago. Wonder if anyone else has had this problem.
May 10, 2022 at 6:32 PM
I don't want to say it's normal, because it isn't, but it was a common issue. Inside the transmission valve body is what is called a separator plate. The plate needed to be removed and replaced with a revised plate. The new separator plate has a .110" diameter orifice to feed transmission fluid to the rear clutch. Also, when this was done, the rear clutch plates were to be replaced, but I assume that was done with the rebuild.
If you look below, I attached a technical service bulletin related to this problem. I'm surprised a transmission shop wasn't aware of this. However, I guess it is getting older and they may not have seen one for some time.
Let me know if this helps.
See pics below.
May 10, 2022 at 8:57 PM
KASHAYA
  • 6 POSTS
Thank you for the information. Also, the shop that did transmission told me that this unit had three clutch plates and they added two more for a total of five. Would this have an effect on the hard shifting?
May 11, 2022 at 1:10 PM
Often times plates are added to reach tolerance. It really shouldn't be causing the hard shift.
You may want to consider contacting them to see if this is something they would consider fixing.
Let me know if I can help in any way.
May 11, 2022 at 7:49 PM
KASHAYA
  • 6 POSTS
Thanks again Joe. Your very helpful.
May 11, 2022 at 8:55 PM
You are very welcome. If you have a chance, let me know how things turn out for you. If you are busy, no problem.
However, please feel free to come back anytime in the future. You are always welcome here.
May 11, 2022 at 9:20 PM
KASHAYA
  • 6 POSTS
Will do, thanks.
May 13, 2022 at 3:08 PM
