When starting the car for the first time in a day all is okay with shifting from park to reverse and to drive after a few hours of running errands. However, when the vehicle is hot for some reason when backing out of a parking space when shifting to drive it will not shift, everything else will works; reverse, park, and neutral, but trying to shift it in drive it will not take. almost as if the vehicle is on neutral. i have changed plates, cleaned the valve body and changed the pressure point on the TCM and still nothing. fluids are also good.
Dec 24, 2021 at 5:32 AM
