Transmission fault on whenever it is slippery
2010 FORD FALCON
180,000 MILES • 6 CYL • RWD • AUTOMATIC
KANGB4U
I get a transmission fault on whenever it is slippery. rpm's go high and when I turn it off and start again it is fine again. I had transmission service done about eight weeks ago.
May 8, 2017 at 7:03 PM
If when you had the service done if they used the wrong fluid it can cause this problem. Second is I would read the codes the car has to see what kind of failure the car is recording.
Here is a guide to show you how to get the codes.
Please run this test and get back to us so we can continue helping you.
May 11, 2017 at 11:32 AM
