Will not go in any gear
1999 LAND ROVER DISCOVERY 2
150,000 MILES • 4.3L • V8 • 4WD • AUTOMATIC
DJACOBS
I have a vehicle that will not go into any gear at all.
Apr 3, 2017 at 9:29 PM
STEVE W.
  • 15,113 POSTS
Do you mean the shifter does not move or that it moves but you get no motion? If the first problem, it is likely the transmission interlock. It is job is to prevent you from shifting into gear without your foot on the brake. It uses a switch on the brakes, the ignition and those trip a solenoid the releases the shifter.
If the second problem, that could be a bad shift cable or the cable disconnected.
To check that you just look at the shift linkage on the transmission as someone else shifts the lever. If it moves fine but still no motion you need a transmission shop to look at it.
Apr 3, 2017 at 10:21 PM
STEVE W.
  • 15,113 POSTS
Have you been able to repair your vehicle or found the problem? Please post back as you may help others with your repair. Thank You.
Steve
Apr 7, 2017 at 10:18 PM
