How and where can I reset the TCM
2002 MERCURY MOUNTAINEER
180,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
LAWRENCE CHENOWETH
  • 39 POSTS
Trying to trouble shoot this thing before I finally give up and pull the transmission.
Oct 1, 2019 at 3:17 AM
BMDOUBLE
  • 1,139 POSTS
The TCM is integrated into the power-train control module (PCM). Here is the official description: Electronic System Description:
The Power-train Control Module (PCM) and its input/output network control the following transmission operations:
^ shift timing.
^ line pressure (shift feel).
^ torque converter clutch.
The transmission control strategy combined with the engine control provides optimum power-train operation under all conditions. When determining the best operating strategy for transmission operation, the PCM uses input information from certain engine-related and driver-demand related sensors and switches.
In addition, the PCM receives input signals from certain transmission-related sensors and switches. The PCM also uses these signals when determining transmission operating strategy.
Using all of these input signals, the PCM can determine when the time and conditions are right for a shift, or when to apply or release the torque converter clutch. It will also determine the pressure needed to optimize shift feel. To accomplish this the PCM uses three pressure control, one torque converter clutch, and four shift solenoids to control transmission operation.
The following provides a brief description of each of the sensors and actuators used to control transmission operation.
The operation of the transmission is controlled by the Power-train Control Module (PCM). Many input sensors provide information to the PCM. The PCM then controls the actuators which determine transmission operation.
Oct 1, 2019 at 3:56 PM
LAWRENCE CHENOWETH
  • 39 POSTS
When I changed valve body and solenoid pack the low and reverse band looked broke. is it hard to change? could you please give me some insight on how to tell and how hard it is to change?
Oct 1, 2019 at 4:19 PM
BMDOUBLE
  • 1,139 POSTS
The main issue with these is the servo bore gets worn out due to the difference in metal type between the servo rod and the case so over time the servo doesn't actuate the band hard enough and causes the band to slip, overheat, then eventually break. There is a company that specializes in repair parts for these servos, fordservoboretransmissionfixsolution.com is their website. This repair should be done at the same time the band or any other part is replaced. As far as difficulty level, I wish I could say it's easy to replace this band but, non way would that be true! It's step 67 in the tear-down procedure just to get to it! There are excellent videos for this transmission tear-down online so I wouldn't be doing you a favor giving you over 100 pictures and documents, but I can get you the torque specs if you get to that point.
Oct 1, 2019 at 5:02 PM
LAWRENCE CHENOWETH
  • 39 POSTS
Do you happen to know of a good website for a complete rebuild kit for this transmission or is there a better transmission I can replace this junk 5r55w transmission with? please and thank you.
Oct 1, 2019 at 5:06 PM
BMDOUBLE
  • 1,139 POSTS
rockauto.com is pretty good because they give you multiple options for kits.
Oct 1, 2019 at 5:59 PM
LAWRENCE CHENOWETH
  • 39 POSTS
Thank you if I have anymore questions I'll let you all know. You have been all very helpful and always respond fast. thank you all for caring for us shade tree guys who don't have a lot of money.
Oct 1, 2019 at 6:05 PM
BMDOUBLE
  • 1,139 POSTS
Anytime my friend! we're here for you because we've all been there!
Oct 1, 2019 at 6:36 PM
