Transmission will not go into third gear or drive
2004 BUICK LESABRE
150,000 MILES • 2WD • AUTOMATIC
FRANKIJO515
The car will go into first, second, and reverse, but not third or drive.
Dec 7, 2018 at 11:40 PM
It sounds like you have a turbine shaft speed sensor or a gear range sensor issue but we need to run the codes first. Here is a guide:
Also please check the transmission fluid level as well. Is it leaking?
Dec 10, 2018 at 12:22 PM
